code défaut
Discussion dans '1.9L (4 cylindres)' créé par jef 62, 26 Décembre 2012.
  1. jef 62
    jef 62 Accro
    Noyelles-les-Vermelles, France
    Q3 2.0 tdi 140 ambiante
    11/2012
    45000
    cffb
    salut à tous .
    voilà j'ai scaner le tuture du cousin et voilà ce qu'il en ressort.
    pouvez vous m'éclairer svp.
    merci d'avance
    Wednesday,26,December,2012,18:07:04:46862
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 7D
    VIN: WVWZZZ1KZ5B065027 Mileage: 160540km/99754miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    7D-Aux. Heat -- Status: Cannot be reached 1100
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 CB HW: 028 101 190 0
    Component: R4 1,9L EDC 0000SG 6176
    Revision: 12345678 Serial number: VWZ7Z0D0784764
    Coding: 0000071
    Shop #: WSC 00046 412 16384
    VCID: 65CAB3CA933BD034
    3 Faults Found
    17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
    P0671 - 000 - -
    Freeze Frame:
    RPM: 903 /min
    Torque: 54.0 Nm
    Speed: 0.0 km/h
    Load: 1.6 %
    Voltage: 13.91 V
    Bin. Bits: 11000100
    Temperature: 14.4°C
    Bin. Bits: 10110000
    18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83): Signal too High
    P2185 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 2.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.93 V
    Bin. Bits: 00000100
    Temperature: 18.0°C
    Temperature: 9.9°C
    17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
    P0674 - 000 - -
    Freeze Frame:
    RPM: 924 /min
    Torque: 52.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 11000100
    Temperature: 2.7°C
    Bin. Bits: 10110000
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
    Part No: 1K0 907 379 N
    Component: ASR FRONT MK70 0103
    Coding: 0017025
    VCID: 3D7A3BAA5B2BB8F4
    No fault code found.
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 CR
    Component: Climatic PQ35 081 0404
    Shop #: WSC 00000 000 00000
    VCID: 76E8E4863E9D2BAC
    1 Fault Found
    01207 - Control Module for Auxiliary Heater (J364)
    004 - No Signal/Communication
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
    Component: Bordnetz-SG 1.0 H29 0704
    Revision: 00029000 Serial number: 00000001228388
    Coding: 01890F0600041800001400001400000000
    Shop #: WSC 00046 412 417792
    VCID: 4084425E2CD9D51C
    Part No: 1K1 955 119 B
    Component: Wischer VW350 012 0401
    Coding: 00065493
    Shop #: WSC 00046
    1 Fault Found
    00483 - Control Module for Auxiliary Air Heater
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
    Component: 01 AIRBAG VW8 023 0700
    Revision: 06023000 Serial number: 00385D0MACL8
    Coding: 0012337
    Shop #: WSC 00046 412 434176
    VCID: 3162179A97734C94
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 HW: 1K0 953 549
    Component: Lenksäulenmodul 012 0030
    Coding: 0000002
    Shop #: WSC 00046 412 1220608
    VCID: EFE651E2C1C79A64
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K0 920 851 H
    Component: KOMBIINSTRUMENT VDD 0716
    Coding: 0003103
    Shop #: WSC 04377 995 69664
    VCID: 2D5A0BEA8B4B2874
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 E HW: 1K0 907 951
    Component: Gateway H09 0110
    Revision: 09 Serial number: 27001049300224
    Coding: 3D0F0B00070002
    Shop #: WSC 00046 412 131072
    VCID: 2952FFFABFA33454
    1 Fault Found
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 102
    Mileage: 119173 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:12:14
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Component: IMMO VDD 0716
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
    Part No: 1K0 959 701 E
    Component: Tuersteuergeraet 09 0153
    Coding: 0000052
    VCID: 3064129E9C79459C
    1 Fault Found
    00943 - Heated Exterior Mirror; Driver Side (Z4)
    012 - Electrical Fault in Circuit
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K1 909 144 G
    Component: EPS_ZFLS Kl.2 1401
    VCID: 2F6611E281475A64
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 BL
    Component: 01 KSG 0301
    Coding: 80C802087F2D8404084B01E010
    VCID: 7BFEF5B205BF76C4
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1K0 959 702 E
    Coding: 0000052
    Address 7D: Aux. Heat
    Cannot be reached
    End ---------------------------------------------------------------------
    Wednesday,26,December,2012,18:15:36:46862
    Chassis Type: 1K0
    Coding: 0000071
    3 Faults Found
    P0671 - 000 - -
    Freeze Frame:
    RPM: 903 /min
    Torque: 54.0 Nm
    Speed: 0.0 km/h
    Load: 1.6 %
    Voltage: 13.91 V
    Bin. Bits: 11000100
    Temperature: 14.4°C
    Bin. Bits: 10110000
    Freeze Frame:
    RPM: 0 /min
    Torque: 2.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.93 V
    Bin. Bits: 00000100
    Temperature: 18.0°C
    Temperature: 9.9°C
    P0674 - 000 - -
    Freeze Frame:
    RPM: 924 /min
    Torque: 52.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 11000100
    Temperature: 2.7°C
    Bin. Bits: 10110000
    Coding: 0017025
    1 Fault Found
    Coding: 00065493
    Shop #: WSC 00046
    1 Fault Found
    Coding: 0012337
    Coding: 0000002
    Coding: 0003103
    1 Fault Found
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 102
    Mileage: 119173 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:12:14
    Coding: 0000052
    1 Fault Found
    Coding: 0000052
    Cannot be reached
  3. remyj
    Feyzin, France
    Golf 6
    80000
  4. jef 62
    jef 62 Accro
    11/2012
    45000
    cffb
    Re : code défaut
    merci remyj.
    concernant les codes 00483
    01207
    18617(P2185)
    Control Module for Auxiliary Heater (J364) ou se trouve ce relais ou fusible
    tu à quelque chose là dessus stp
