Correction excessive de l'avance par le calculateur
Discussion dans 'Moteur TDI' créé par samuel2635, 25 Avril 2010.
  1. samuel2635
    samuel2635 Enthousiaste
    Bonjour à tous !
    J'aurai besoin d'un avis concernant l'avance à l'injection sur un Tdi 110 AFN
    donc j'ai fais un log en réglage de base moteur à 92 °c :
    ,Group A:,'000,,,,,,,,,,Group B:, Not Running,,,,Group C:, Not Running
    ,TIME,,,,,,,,,,,TIME,,,,,TIME,,,,
    Marker,STAMP,,,,,,,,,,,,STAMP,,,,,STAMP,,,
    ,0.01,043,020,000,024,098,201,061,125,171,128,,,,,,,,,,
    ,0.59,043,022,000,023,098,201,061,125,171,127,,,,,,,,,,
    ,1.18,043,021,000,023,098,201,061,125,171,126,,,,,,,,,,
    ,1.76,043,021,000,024,098,201,061,125,171,131,,,,,,,,,,
    ,2.34,043,023,000,023,098,201,061,125,171,126,,,,,,,,,,
    ,2.91,043,021,000,023,099,201,061,125,171,128,,,,,,,,,,
    ,3.49,043,022,000,024,098,201,061,125,171,128,,,,,,,,,,
    ,4.07,043,021,000,024,098,201,061,125,171,127,,,,,,,,,,
    ,4.65,043,020,000,024,098,201,061,125,171,131,,,,,,,,,,
    ,5.25,043,023,000,024,098,201,061,125,171,131,,,,,,,,,,
    ,5.84,043,022,000,023,098,201,061,125,171,132,,,,,,,,,,
    ,6.46,043,022,000,024,099,201,061,125,171,129,,,,,,,,,,
    ,7.07,043,021,000,024,098,201,061,125,171,125,,,,,,,,,,
    ,7.65,043,022,000,024,098,201,061,125,171,126,,,,,,,,,,
    ,8.25,043,021,000,023,099,201,061,125,171,129,,,,,,,,,,
    ,8.84,043,023,000,024,098,201,061,125,171,131,,,,,,,,,,
    ,9.43,043,023,000,023,098,201,061,125,171,129,,,,,,,,,,
    ,10.03,043,023,000,024,098,201,061,125,171,127,,,,,,,,,,
    ,10.62,043,022,000,023,098,201,060,125,171,126,,,,,,,,,,
    ,11.22,043,020,000,024,099,201,060,125,171,131,,,,,,,,,,
    ,11.81,043,022,000,023,098,201,061,125,171,128,,,,,,,,,,
    ,12.40,043,020,000,024,098,201,060,125,171,131,,,,,,,,,,
    ,13.01,043,024,000,023,098,201,060,125,171,132,,,,,,,,,,
    ,13.61,043,021,000,023,098,201,060,125,171,127,,,,,,,,,,
    ,14.20,043,022,000,023,098,201,060,125,171,125,,,,,,,,,,
    ,14.79,043,022,000,024,098,201,060,125,171,129,,,,,,,,,,
    ,15.39,043,019,000,024,098,201,060,125,171,127,,,,,,,,,,
    ,15.98,043,021,000,023,098,201,060,125,171,127,,,,,,,,,,
    ,16.58,043,021,000,023,098,201,060,125,171,133,,,,,,,,,,
    ,17.17,043,023,000,023,098,201,060,125,171,130,,,,,,,,,,
    ,17.76,043,022,000,024,098,201,060,125,171,129,,,,,,,,,,
    Comparaison avec la correction du calculateur :
    ,0.01,043,052,000,023,098,201,061,127,169,130,,,,,,,,,,
    ,0.60,043,059,000,023,098,201,061,127,169,131,,,,,,,,,,
    ,1.19,043,050,000,023,098,201,061,127,169,129,,,,,,,,,,
    ,1.77,043,059,000,023,098,201,061,127,169,127,,,,,,,,,,
    ,2.36,043,054,000,023,098,201,061,127,169,128,,,,,,,,,,
    ,2.96,043,058,000,023,098,201,062,127,169,133,,,,,,,,,,
    ,3.57,043,053,000,022,098,201,062,127,169,134,,,,,,,,,,
    ,4.18,043,055,000,023,098,201,062,127,169,121,,,,,,,,,,
    ,4.77,043,053,000,023,098,201,062,127,169,131,,,,,,,,,,
    ,5.36,043,056,000,023,098,201,062,127,169,128,,,,,,,,,,
    ,5.96,043,054,000,023,098,201,062,127,169,129,,,,,,,,,,
    ,6.55,043,060,000,024,098,201,062,127,169,129,,,,,,,,,,
    ,7.14,043,057,000,023,098,201,062,127,169,130,,,,,,,,,,
    ,7.74,043,054,000,023,098,201,063,127,169,128,,,,,,,,,,
    ,8.33,043,059,000,023,098,201,063,127,169,129,,,,,,,,,,
    ,8.92,043,059,000,023,098,201,063,127,169,125,,,,,,,,,,
    ,9.52,043,056,000,023,099,201,063,127,169,129,,,,,,,,,,
    ,10.13,043,053,000,023,099,201,063,127,169,132,,,,,,,,,,
    ,10.75,043,057,000,023,098,201,063,127,169,129,,,,,,,,,,
    ,11.33,043,063,000,023,098,201,063,127,169,134,,,,,,,,,,
    ,11.92,043,057,000,023,099,201,063,127,169,131,,,,,,,,,,
    ,12.52,043,050,000,023,098,201,063,127,169,128,,,,,,,,,,
    ,13.11,043,055,000,024,098,201,064,127,169,126,,,,,,,,,,
    ,13.71,043,058,000,023,098,201,064,127,169,125,,,,,,,,,,
    Je suis en bas du graph en réglage de base et aprés correction : 50 à 63 en dépassement de la tolérance haute ; je ne comprends pas pourquoi la correction du calculateur est aussi élevée !
    En dépit de cela , la voiture ne consomme pas trop (5 à 5,5 L), fume blanc à l'accéleration et un peu au démarrage, avec vag.com groupe de mesure 4 , j'ai remarqué que la solenoide d'avance est a 55 % au ralenti , en charge elle monte jusqu'a 86 % et la température du gasoil à chaud est à 44°c
    J'ai remarqué que moteur chaud, à 90 °c , elle ne fume pas du tout , cependant elle ne monte quasi jamais à cette temperature, 75 °c à 80 °c en moyenne ( je pense à une sonde )
    j'ai surtout pu constater qu'il y avait quelques bulles d'air à la sortie du filtre gasoil de façon sporadique , je ne sais pas si c'est normal et si cela peut influencer autant l'avance à l'injection, je viens de commander une soupape anti retour de filtre neuve en pensant que ça puisse venir de ça .
    Faut-il que je modifie l'avance ?
  3. samuel2635
    Re : Correction excessive de l'avance par le calculateur
    Personne pour me renseigner ?
    :cry:
    ps : C'est vrai que mon post est un peu long :D
