Débimetre ou pas ?????
Discussion dans '1.9L (4 cylindres)' créé par laurenzo44, 23 Février 2013.
  1. Bonjour a tous, suite a des coupure moteur je me demande si mon debimetre ne serait pas la cause ????
    PS : le turbo vient d etre nettoyé et remonté, il n est pas grippé
    N 75 neuve
    Toutes les durites neuves et bien branché, j ai verifié.
    Alors que penser de se LOG ????? Par avance merci.
    Group A:,'003,,,,Group B:,'013,,,,Group C:,'015
    ,,RPM,Mass Air / Rev.,Mass Air / Rev.,Duty Cycle,,Inj. Quantity,Inj. Quantity,Inj. Quantity,Inj. Quantity,,RPM,Inj. Quantity,Fuel Consump.,Inj. Quantity
    ,TIME,,,,,TIME,,,,,TIME,,,,
    Marker,STAMP, /min, mg/str, mg/str, %,STAMP, mg/str, mg/str, mg/str, mg/str,STAMP, /min, mg/str, l/h, mg/str
    ,0.62,1596,550.0,620.0,79.7,0.95,0.24,-0.45,-0.09,0.31,0.30,1575,18.4,4.20,18.4
    ,1.61,1638,540.0,625.0,79.7,1.97,0.24,-0.45,-0.09,0.31,1.26,1638,18.4,4.40,18.4
    ,2.66,1701,460.0,610.0,79.7,2.98,0.24,-0.45,-0.09,0.31,2.33,1680,17.8,4.40,17.8
    ,3.63,1743,550.0,645.0,79.7,3.99,0.24,-0.45,-0.09,0.31,3.30,1743,19.2,4.80,19.2
    ,4.71,1785,385.0,600.0,79.7,5.06,0.24,-0.45,-0.09,0.31,4.35,1785,14.2,3.70,14.0
    ,5.70,1785,365.0,655.0,79.7,6.02,0.24,-0.45,-0.09,0.31,5.38,1785,9.0,2.30,9.0
    ,6.68,1701,250.0,635.0,79.7,7.03,0.24,-0.45,-0.09,0.31,6.35,1764,6.6,1.70,6.6
    ,7.72,1638,250.0,600.0,79.7,8.04,0.24,-0.45,-0.09,0.31,7.39,1680,0.0,0.00,0.0
    ,8.68,1575,350.0,605.0,78.1,9.03,0.24,-0.45,-0.09,0.31,8.36,1575,3.0,0.70,3.0
    ,9.75,1554,480.0,675.0,79.7,10.09,0.24,-0.42,-0.12,0.28,9.39,1554,13.8,3.10,13.8
    ,10.72,1575,500.0,715.0,79.7,11.04,0.28,-0.42,-0.12,0.28,10.40,1575,13.8,3.20,13.8
    ,11.73,1617,490.0,735.0,79.7,12.09,0.28,-0.45,-0.12,0.28,11.36,1596,15.0,3.50,15.0
    ,12.74,1659,455.0,640.0,79.7,13.06,0.28,-0.45,-0.12,0.28,12.43,1659,14.0,3.40,14.0
    ,13.71,1743,865.0,650.0,57.0,14.07,0.28,-0.45,-0.12,0.28,13.38,1701,14.0,3.40,14.0
    ,14.79,1932,850.0,995.0,4.8,15.11,0.28,-0.45,-0.12,0.28,14.43,1848,41.4,11.20,46.0
    ,15.76,2163,850.0,1130.0,4.8,16.08,0.28,-0.45,-0.12,0.28,15.44,2100,42.0,12.80,45.2
    ,16.77,2415,850.0,885.0,4.8,17.13,0.28,-0.45,-0.12,0.28,16.40,2331,41.8,14.20,44.8
    ,17.81,2667,850.0,895.0,4.8,18.12,0.28,-0.45,-0.12,0.28,17.49,2583,41.4,15.50,44.4
    ,18.76,2877,850.0,915.0,4.8,19.08,0.28,-0.45,-0.12,0.28,18.44,2793,41.0,16.80,44.2
    ,19.79,3087,850.0,925.0,4.8,20.15,0.28,-0.45,-0.12,0.28,19.43,3003,40.8,17.90,44.0
    ,20.78,3297,850.0,925.0,4.8,21.10,0.28,-0.45,-0.12,0.28,20.46,3234,40.4,19.10,44.0
    ,21.75,3507,850.0,915.0,4.8,22.11,0.28,-0.45,-0.12,0.28,21.42,3444,40.0,20.10,44.0
    ,22.81,3717,850.0,895.0,4.8,23.14,0.28,-0.45,-0.12,0.28,22.47,3654,39.6,21.10,44.0
    ,23.78,3906,850.0,880.0,4.8,24.10,0.28,-0.45,-0.12,0.28,23.46,3843,39.0,21.90,44.0
    ,24.81,4074,850.0,865.0,4.8,25.16,0.28,-0.45,-0.12,0.28,24.45,4011,38.4,22.50,44.0
    ,25.80,3066,255.0,700.0,4.8,26.12,0.28,-0.45,-0.12,0.28,25.48,3885,0.0,0.00,0.0
    ,26.77,2835,850.0,1155.0,4.8,27.13,0.28,-0.45,-0.12,0.28,26.44,2835,41.0,16.90,44.0
    ,27.85,2919,850.0,1125.0,4.8,28.19,0.28,-0.45,-0.12,0.28,27.49,2898,41.0,17.30,44.0
    ,28.81,2982,850.0,985.0,4.8,29.14,0.28,-0.45,-0.12,0.28,28.49,2961,40.8,17.60,44.0
    ,29.82,3066,850.0,915.0,4.8,30.18,0.28,-0.45,-0.12,0.28,29.47,3045,40.8,18.00,44.0
    ,30.84,3150,850.0,915.0,4.8,31.15,0.28,-0.45,-0.12,0.28,30.52,3129,40.6,18.50,44.0
    ,31.79,3213,850.0,930.0,4.8,32.12,0.28,-0.45,-0.12,0.28,31.47,3192,40.6,18.90,44.0
    ,32.84,3255,850.0,760.0,4.8,33.18,0.28,-0.45,-0.12,0.28,32.48,3255,35.4,17.30,44.0
    ,33.83,3255,850.0,640.0,4.8,34.15,0.28,-0.45,-0.12,0.28,33.51,3255,19.4,9.20,44.0
    ,34.82,3087,255.0,465.0,4.8,35.18,0.28,-0.45,-0.12,0.28,34.47,3192,0.0,0.00,0.0
    ,35.87,1932,460.0,455.0,40.2,36.19,0.28,-0.45,-0.12,0.28,35.54,2058,0.0,0.00,0.0
    ,36.83,2562,850.0,575.0,4.8,37.17,0.28,-0.45,-0.12,0.28,36.51,2562,22.4,8.40,43.8
    ,37.88,2541,250.0,500.0,79.7,38.23,0.28,-0.45,-0.12,0.28,37.52,2562,22.4,8.40,39.8
    ,38.88,2478,250.0,455.0,4.8,39.19,0.28,-0.45,-0.12,0.28,38.55,2499,0.0,0.00,0.0
    ,39.88,2436,250.0,460.0,4.8,40.24,0.28,-0.45,-0.12,0.28,39.52,2457,0.0,0.00,0.0
    ,40.91,2373,250.0,460.0,4.8,41.23,0.28,-0.45,-0.12,0.28,40.60,2394,0.0,0.00,0.0
    ,104.68,861,290.0,445.0,79.7,105.03,-0.09,-0.26,0.12,0.21,104.33,861,5.8,0.70,0.0
    Voiture concernée : Audi a6 - afn - 1.9L TDI
  3. Re : Débimetre ou pas ?????
    Non, d'après les logs, ton débitmètre va bien.
  4. Re : Débimetre ou pas ?????
    ok merci merci
