deffaut P8003 sur passat v 130 ch
Discussion dans '1.9L (4 cylindres)' créé par ZIZOU73, 28 Novembre 2012.
  1. ZIZOU73
    ZIZOU73 Débutant
    Sétif, Algeria
    PASSA 3BG
    322000
    AWX
    j'ai des vibrations sur mon moteur awx de mon passat 2002 de 200000km et avec la vagcom j'ai relevé un deffaut p3008.et voila quelques parametres.
    aidez moi.
    Monday,22,November,2010,18:47:38:13314
    VCDS Version: Release 908.0
    Data version: 20090911
    Address 01: Engine (038 906 019 GS)
    18:47:17 Group 013: Idle Speed Smooth Running Control
    -0.66 mg/str Cyl 1 -2.8 to +2.8 mg/H
    -0.80 mg/str Cyl 2 -2.8 to +2.8 mg/H
    0.94 mg/str Cyl 3 -2.8 to +2.8 mg/H
    0.47 mg/str Cyl 4 -2.8 to +2.8 mg/H
    18:47:17 Group 003: EGR (Exhaust Gases Recycling)
    861 /min Engine speed 790-870
    250.0 mg/str MAF (specified) 230-310
    426.3 mg/str MAF (actual) 210-350
    4.8 % EGR duty cycle 40-75%
    18:47:17 Group 002: Idle Speed (See label file for #3)
    0.0 % Throttle pos 0%
    0 1 0 Operating Cond/AC speed/throttle/AC
    87.3°C Coolant Temp 80-110°C
    Monday,22,November,2010,18:46:09:13314
    18:45:43 Group 011: Charge pressure control (3rd gear - 3000rpm - full load)
    861 /min Engine speed 2850-3150
    1060.8 mbar Spec. intake press. 2200-2400
    1006.2 Actual intake press. 2100-2600
    19.9 % D.cycle MAP 35-80%
    18:45:43 Group 004: Unit Injectors valves command
    882 /min Engine speed 790-870
    -0.0 °ATDC Spec start of inj. 4BTDC-2ATDC
    6.6°KW Spec inj. duration 3-8 °Ck.
    3.3°KW Synchro. angle -3..+3°Ck.
    18:45:43 Group 012: Glow Plugs (see label file for #1)
    11111111 Glow status all 1's=off
    0.00 Pre-glow period
    14.29 V Supply Voltage
    85.5°C Coolant Temp *C
    Monday,22,November,2010,18:42:57:13314
    18:42:37 Group 013: Idle Speed Smooth Running Control
    -0.56 mg/str Cyl 1 -2.8 to +2.8 mg/H
    -0.68 mg/str Cyl 2 -2.8 to +2.8 mg/H
    0.85 mg/str Cyl 3 -2.8 to +2.8 mg/H
    0.38 mg/str Cyl 4 -2.8 to +2.8 mg/H
    18:42:37 Group 001: Injected quantity
    5.5 mg/str Injected quantity 3.0-9.0
    6.6°KW Spec. Inj. duration 3-8 °Ck.
    82.8°C Coolant temp 80-110°C
    18:42:37 Group 011: Charge pressure control (3rd gear - 3000rpm - full load)
    1040.4 mbar Spec. intake press. 2200-2400
  3. audimanrs2
    Sancoins, France
    salut zizou.le défaut est du au:[TABLE]
    [TR]
    [TD]
    • Capteur de position d'arbre à cames (G40) .
    • Vérifier / réparer le câblage et les connexions
    • Contrôler le calage
    • Capteur de position d'arbre à cames vérifier
    • Vérifier le montage du capteur de position d'arbre à cames
      a+gégé
    [/TD]
    [/TR]
    [/TABLE]
  4. ZIZOU73
    ZIZOU73 Débutant
    Sétif, Algeria
    PASSA 3BG
    322000
    AWX
    j'ai oublier de dire q'apres un reset pas de deffaut.
    j'ai une autre question dans le groupe 4 l'angle de synchronisation est hors tolerence.
  5. leon4motion
    leon4motion Débutant
    bonjour qui a fait la distribution sur ton véhicule???
  6. MacGUYvert
    Bonjour à TOUS
    Il faut comme le dit AudimanRS2 absolument vérifier le cablage et son blindage allant G40 : car il s'agit d 'un signal sinusoïdal très sensible aux champs magnétiques reignants dans le compartiment moteur ( moteurs électrique, diodes d 'alternateur ) qui peuvent fausser de plusieurs degrés la position effective de l 'AAC ....
  7. caramail12
    caramail12 Modérateur
    Rodez, France
    Salut
    Tu as déja eu des problemes de demarrage plutoT long ,?
    3.3°KW Synchro. angle -3..+3°Ck. Il me semble que ces valeurs sont celle de l'avance à l'injection , tu peux adapter cette valeur en modifiant le réglage de la poule d'arbre à came .
    Je sais pas dans quelle condition tu as relevé ces valeurs mais , les valeur de l'egr ne sont pas correcte comme si ta vanne egr resté légèrement ouverte , controle là
    Les valeurs injecteurs sont correctes .18:47:17 Group 013: Idle Speed Smooth Running Control
  8. ZIZOU73
    ZIZOU73 Débutant
    Sétif, Algeria
    PASSA 3BG
    322000
    AWX
    ma vanne EGR est bloqué par deux tôles et j'ai toujours un défaut de cette vanne qui dit q'elle est a la masse ou en court circuit.
    et concernant mon angle de synchronisation qui est 3.3 comment je règle la poulie d'ACC et dans quel sens.
    et qu'elle est l'influence de cette angle sur le fonctionnement du moteur.
    et je suis decatalyse .
    merci.
  9. ZIZOU73
    ZIZOU73 Débutant
    Sétif, Algeria
    PASSA 3BG
    322000
    AWX
    aidez moi mes amis
  10. caramail12
    Rodez, France
    Tu n'as pas répondu ; T'es demarrage sont long par moment ou pas ?
    Les vibrations , à 2000 tours ? au ralentie à l'arret , en sous régime , .
    Si tu veux de l'aide ici il te faut forcément nous préciser a quel moment sont tes vibrations .
    Quant tu as bouché la vanne egr les vibrations étaient déja présentes ,?
    Les vibrations sont présentes à chaud à froid .
    Les vibrations s'amplifient proportionnellement au régime moteur ?
  11. ZIZOU73
    ZIZOU73 Débutant
    Sétif, Algeria
    PASSA 3BG
    322000
    AWX
    mes démarrage sont normales.
    mes vibrations sont a l’arrêt au ralentit a froid comme a chaud.
    ma vanne EGR est condamne il y'a longtemps presque six mois elle été bien avant et après.
    merci pour votre aide.
  13. ZIZOU73
    ZIZOU73 Débutant
    Sétif, Algeria
    PASSA 3BG
    322000
    AWX
    :-Fureur-: y'a quelq'un:-Fureur-:
  14. mostapha
    mostapha Nouveau
    oui tu es un problem
  15. audimanrs2
    Sancoins, France
    salut zizou.pour t'aider,il faudrait que tu répondes a toutes les questions posées.leon4motion t'as demandé si la distrib a été faite il y a longtemp et par qui,ensuites as tu vérifié les solution que je t'ai données,la vanne egr a été supprimée physiquement mais a tu supprimé via vagcom.a+gégé
  16. ZIZOU73
    ZIZOU73 Débutant
    Sétif, Algeria
    PASSA 3BG
    322000
    AWX
    bon je vais répondre à toutes vous question
    1) je précise que le Default est disparu après reset via vagcom et n'a pas apparaît.
    2) ma distribution est faite par l'ancien propriétaire et lui a 140000 km donc elle a 60000 km.
    3) ma vanne EGR supprime physiquement par deux plaques metaliques.
    4) mon catalyseur est vide.
    ce qui m'inquiette c'est deux chose en rouge dans la groupe 003 et le groupe 004
  17. ZIZOU73
    ZIZOU73 Débutant
    Sétif, Algeria
    PASSA 3BG
    322000
    AWX
    aidez moiiiiiiiiiiii
  18. blue léon
    blue léon Enthousiaste
    Courthezon, France
    +3,3 ° !! ta distribution est mal calée ,la moyenne c'est -3° +3° ..............
  19. leon4motion
    oui ton maf moi perso j ai la meme chose apres moi je prendrais du temps pour réglé mon aac a mon avis avec lumiers de la poulie aac ou tu a les trois boulons pour regler l avance tu va voir de quelle coter il va falloir que tu tourne pour arbre a came jusqu a cas se que tu trouve 0° serai le top du réglage bon courage ta pu cas
    http://www.vag-technique.fr/showthr...-injection-TDI-IP?highlight=reglage+injection
    regarde cela ca pourrai aidez merci a lionel !!!
  20. ZIZOU73
    ZIZOU73 Débutant
    Sétif, Algeria
    PASSA 3BG
    322000
    AWX
    j'attends vos réponses
  21. leon4motion
    Tu a reglé ton AAC ???
  22. ZIZOU73
    ZIZOU73 Débutant
    Sétif, Algeria
    PASSA 3BG
    322000
    AWX
    non pas encore
