Erreurs suite à Scan ODB
Discussion dans 'Equipements électriques' créé par vigvig, 23 Janvier 2011.
  1. vigvig
    vigvig Enthousiaste
    09/2001
    274000
    AWX
    7
    J'ai recu mon interface pour ma Passat 3C de 2005, j'ai trouvé ces erreurs, est ce grave ?
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
    Part No SW: 3C0 614 095 K HW: 3C0 614 095 K
    Component: ESP 440 C2 H015 0001
    Revision: H015 Serial number: 0657184436
    Coding: 0013602
    Shop #: WSC 00028 028 00001
    VCID: 2A5000F6BAA53F4C
    1 Fault Found
    02840 - Wake-Up Line from Central Convenience Module
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 154
    Time Indication: 0
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 A HW: 3C0 909 605 A
    Component: 0B AIRBAG VW8 028 2321
    Revision: 06028000 Serial number: 0034ZS405LP$
    Coding: 0012354
    VCID: 244CEECED881E93C
    1 Fault Found
    01316 - ABS Control Module
    004 - No Signal/Communication - Intermittent
    Address 18: Aux. Heat Labels: None
    Part No: 1K0 815 071 H
    Component: Zuheizer 031 1312
    Revision: A Serial number: 09010046
    Coding: 0000012
    4 Faults Found
    00664 - Fuel gauge
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 30
    Reset counter: 134
    Mileage: 197859 km
    Time Indication: 0
    Date: 2010.12.27
    Time: 18:46:47
    01415 - Recirculating Pump (V55)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 0
    Reset counter: 161
    Mileage: 198664 km
    Time Indication: 0
    Date: 2011.01.12
    Time: 16:33:25
    Freeze Frame:
    OFF
    Temperature: 12.0°C
    Temperature: 21.0°C
    02251 - Heater Unit Locked
    000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Reset counter: 161
    Mileage: 198664 km
    Time Indication: 0
    Date: 2011.01.12
    Time: 16:33:25
    01408 - Under-Voltage Shut-Off (fixed Value)
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 219
    Mileage: 119293 km
    Time Indication: 0
    Date: 2010.02.16
    Time: 09:58:12
    Freeze Frame:
    Malfunction
    Temperature: -1.0°C
    Temperature: -3.0°C
    Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
    Part No SW: 3C0 959 433 HW: 3C0 959 433
    Component: IMMO 038 0347
    Revision: 00038000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: E7D639C2E9374224
    Part No: 3C0 905 861 A
    Component: ELV 021 0350
    3C0905861A ELV 021 0350
    1 Fault Found
    02823 - Requirements for Locking the Steering Column Lock not met
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 7
    Fault Frequency: 4
    Reset counter: 155
    Mileage: 0 km
    Time Indication: 0
    Je n'arrive pas à savoir ce qu'il y a pourtant la voiture fonctionne parfaitement. J'ai effacé ces erreurs, et relancé un scan il me trouve toujours ces erreurs...
    Merci d'avance.
    Re : Erreurs suite à Scan ODB
    Tu roules trop avec la jauge à mazout dans le "coma" ce qui rend folle la pompe de gavage et interromp le fonctionnement du réchauffeur additionnel..
    Ensuite, ta batterie est trop vieille et ne peut plus assurer un ampèrage correct pour les " pulses encoders" des calculateurs, ce qui fait que le dialogue ( cross-talk ) est haché ou interrompu.....
    Il faudrait redémarrer le test, moteur déja en route avec ralenti élevé , et le pied sur le frein, pour voir de plus près cette histoire d 'ABS.
    Et si tu as des sous, remplis ton réservoir, et achète une batterie neuve....
    à+ GUY...
