help interpretation erreur vagcom audi A4 1.8l 8H - Audi Cabrio B6/B7
Discussion dans 'Toutes motorisations' créé par fhzero, 19 Août 2011.
  1. hello a tous
    j ai un ami qui est venue faire un diag avec vagcom, le moteur tourne rond mais c est clair qu il y a un manque de puissance quand on tire un peut dedans!
    voici le diag et merci pour vos commentaires"concentrez vous sur le moteur"
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Wednesday,17,August,2011,11:35:04:46862
    Chassis Type: 8H - Audi Cabrio B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 26 36 37 45 46 55 56 57 63
    65 67 73 75 76 77
    VIN: WAUZZZ8H23K026536 Mileage: 134420km/83524miles
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 8E0 909 518 AA HW: 8E0 909 018 A
    Component: 1.8L R4/5VT 0004
    Coding: 0011504
    Shop #: WSC 00672 785 00200
    VCID: 6FE6D1E241C71A64
    2 Faults Found
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
    P1136 - 001 - Upper Limit Exceeded - Intermittent - MIL ON
    16891 - Idle Control System RPM: Higher than Expected.
    P0507 - 001 - Upper Limit Exceeded - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 3429
    Coding: 04475
    Shop #: WSC 00672
    VCID: E5CA33CA133B5034
    No fault code found.
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 J
    Component: A4 Klimaautomat 1116
    Coding: 00100
    Shop #: WSC 00672
    VCID: 2854FAFEA4A90D5C
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00001
    Shop #: WSC 00672
    VCID: 346C1E8E686179BC
    Address 15: Airbags Labels: 8H0-959-655-84.lbl
    Part No: 8H0 959 655 B
    Component: Airbag 8.4EC 1015
    Coding: 0011104
    VCID: 39722FBA4F0384D4
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 F
    Component: Lenksáulenmodul 0308
    Coding: 00011
    Shop #: WSC 00672
    VCID: 366824867E1D6BAC
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8H0 920 930 E
    Component: KOMBI+WEGFAHRS. RB4 D16
    Coding: 00001
    Shop #: WSC 30001
    VCID: 2C5C06EEB051217C
    WAUZZZ8H23K026536 AUZ6Z0C0013718
    1 Fault Found
    01300 - Control Module for Navigation with CD-Rom (J401)
    49-10 - No Communications - Intermittent
    Address 26: Auto Roof Labels: 8H0-959-255.lbl
    Part No: 8H0 959 255
    Component: VSG B6 CABRIO 6185
    Shop #: WSC 48950 143 51132
    VCID: F3EE5D92ADEFBE84
    Address 37: Navigation Labels: Redir Fail!
    Part No: 4B0 919 887 E
    Component: BNS 4.2 H05 BNO 0020
    VCID: 356A238A631B60B4
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8H0 951 178
    Component: Innenraumueberw. 0411
    Coding: 00001
    Shop #: WSC 00000
    VCID: EFE651E2C1C79A64
    3 Faults Found
    01350 - Alarm via Theft Warning System; Rear
    43-00 - Closed
    81-00 - Open
    01349 - Alarm via Theft Warning System; Front
    81-00 - Open
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8H0 959 433 D
    Component: Komfortgerát T3B 1312
    Coding: 06666
    Shop #: WSC 00672
    Part No: 8H1959801A
    Component: Tõrsteuer.FS BRM 0001
    Part No: 8H1959802A
    Component: Tõrsteuer.BF BRM 0001
    Part No: 8H0959801A
    Component: Tõrsteuer.HL BRM 0001
    Part No: 8H0959802A
    Component: Tõrsteuer.HR BRM 0001
    1 Fault Found
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 J
    Component: concert II GRO 0008
    Coding: 13011
    Shop #: WSC 00672
    VCID: 2E580CE6864D536C
    1 Fault Found
    00856 - Radio Antenna
    29-00 - Short to Ground
    Address 63: Entry Assist,D Labels: None
    Part No: 8H0 959 760 A
    Component: EasyEntry F H11 X023
    Coding: 00005
    Shop #: WSC 00065
    Address 73: Entry Assist, P Labels: None
    Component: EasyEntry BF H11 X023
    Coding: 00005
    Shop #: WSC 00065
    Address 76: Park Assist Labels: 8Z0-919-283.lbl
    Part No: 8Z0 919 283 A
    Component: Parkingsyst. A4 RDW D09
    Coding: 00105
    Shop #: WSC 00672
    VCID: 438E4D523DCFCE04
    End ---------------------------------------------------------------------
  3. tonka_a6
    tonka_a6 Modérateur
    Multivan T4
    02/1998
    265000
    ACV
    102
  4. tonka_a6
    tonka_a6 Modérateur
    Multivan T4
    02/1998
    265000
    ACV
    102
  5. Re : help interpretation erreur vagcom audi A4 1.8l 8H - Audi Cabrio B6/B7
    merci tonca
    mais ça ne me dis pas se que tu en pense!
  6. tonka_a6
    tonka_a6 Modérateur
    Multivan T4
    02/1998
    265000
    ACV
    102
    il parle du système à vide vaccum
    regarde un peu les lien ( utilise google traduction)
    voila
