ma passat ne démare pas a cause de l'eau
Discussion dans 'Vos Questions, Remarques, Rappels, Mésaventures, .' créé par houss55, 18 Octobre 2013.
  1. houss55
    houss55 Nouveau
    j'ai un probléme dans ma passat ne démare pas
    LE CALCULATEUR DE LA BOITE AUTO NE FONCTIONNE PAS avec vcds
    airbag reste tjr allumer
    ABS reste tjr allumer
    que peux m'aider s.V.p
    -:lov1:-
    Chassis Type: 3B - VW Passat B5
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    Mileage: 212610km/132109miles
    Address 01: Engine Labels: 059-907-401-AKE.lbl
    Part No: 3B1 907 401 B
    Component: 2.5l/4VTEDC G000AG D01
    Coding: 03011
    Shop #: WSC 00001
    VCID: 1D3ADB2AFBEBD8F4
    WVWZZZ3BZ1P140072 VWZ7Z0A3359968
    5 Faults Found
    18034 - Powertrain Data Bus: Missing Message from TCU
    P1626 - 35-10 - - - Intermittent
    01318 - Control Module for Injection Pump (J399)
    49-10 - No Communications - Intermittent
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 35-10 - - - Intermittent
    18044 - Powertrain Data Bus: Missing Message from Airbag Controller
    P1636 - 35-10 - - - Intermittent
    18057 - Powertrain Data Bus: Missing Message from ABS Controller
    P1649 - 35-00 - -
    Readiness: N/A
    Address 03: ABS Brakes Labels: 8D0-907-389.lbl
    Part No: 8D0 907 389 D
    Component: ABS/ESP front D56
    Coding: 04257
    Shop #: WSC 00028
    VCID: 346C1E8E686179BC
    3 Faults Found
    18031 - Powertrain Data Bus: No Communication
    P1623 - 35-00 - -
    Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
    Part No: 3B1 907 044 J
    Component: CLIMATRONIC B5GP 0002
    Coding: 17000
    Shop #: WSC 00028
    VCID: 2854FAFEA4A90D5C
    2 Faults Found
    01299 - Diagnostic Interface for Data Bus (J533)
    79-00 - Please Check Fault Codes
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 6Q0 909 605 B
    Component: 0A AIRBAG VW5 04 0006
    Coding: 12353
    Shop #: WSC 00028
    VCID: 366824867E1D6BAC
    1 Fault Found
    49-00 - No Communications
    Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
    Part No: 1J0 907 487 B
    Component: Lenkradelektronik 0002
    Coding: 00008
    Shop #: WSC 00028
    VCID: 3064129E9C79459C
    No fault code found.
    Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
    Part No: 3B0 920 845 A
    Component: KOMBI+WEGFAHRSP VDO V13
    Coding: 21105
    Shop #: WSC 01236
    VCID: 2240E8D6C295E70C
    5 Faults Found
    01314 - Engine Control Module
    01316 - ABS Control Module
    01321 - Control Module for Airbags (J234)
    01315 - Transmission Control Module
    01330 - Central Control Module for Central Convenience (J393)
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway KCAN 0001
    Coding: 00006
    Shop #: WSC 00028
    VCID: F0E4529EDCF9859C
    7 Faults Found
    00778 - Steering Angle Sensor (G85)
    Address 36: Seat Mem. Drvr Labels: 3B1-959-760.lbl
    Part No: 3B1 959 760 D
    Component: Sitzverstellung 0101
    Shop #: WSC 00000 000 00000
    VCID: 2E580CE6864D536C
    2 Faults Found
    004 - No Signal/Communication
    Re : ma passat ne démare pas a cause de l'eau
    Bonjour Houss
    La il y en a trop !!! Tu as joué au *** avec ta batterie : démarrage aux cables à l 'aide d'un autre véhicule ou remplacement de la batterie avec inversion de polarité , car tous les calculateurs ne communiquent plus entre eux !!!
    Direction la ferraille !!!!!
  4. houss55
    houss55 Nouveau
    J'ai un masse, mais je ne trouve pas.:evil:que peux m'aider ??????? -:lov1:-
