Perte de puissance sur Audi A3 TDI 105 8P
Discussion dans '1.9L (4 cylindres)' créé par amistadjo, 6 Juin 2013.
  1. J'ai un a3 tdi 105 8P de 2007 qui a un probleme de perte de puissance elle a une boite auto dsg 1ere generation j'ai fais un diag
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Control Module Part Number: 03G 906 021 LS HW: 03G 906 021 LS
    Component and/or Version: R4 1,9L EDC 000AG 8552
    Software Coding: 0000078
    Work Shop Code: WSC 02974 995 88202
    VCID: 7BFEF5B205BF76C4
    1 Fault Found
    000665 - Boost Pressure Regulation: Control Range Not Reached
    P0299 - 000 - -
    Freeze Frame
    Fault Status: 01110000
    Fault Priority: 0
    Fault Frequency: 49
    Mileage: 125678 km
    Time Indication: 0
    Date: 2013.02.28
    Time: 21:46:25
    Freeze Frame
    RPM: 2667 /min
    Speed: 110.0 km/h
    Load: 89.8 %
    Voltage: 14.59 V
    Bin. Bits: 11000000
    Absolute Pres.: 2029.8 mbar
    Absolute Pres.: 1499.4 mbar
    Readiness: 1 1 0 0 0
    Address 01: DTCs cleared
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
    VIN: WAUZZZ8P47A100963 Mileage: 129970km/80759miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Part No SW: 03G 906 021 LS HW: 03G 906 021 LS
    Component: R4 1,9L EDC 000AG 8552
    Revision: --H06--- Serial number: AUX7Z0F9FNN04I
    Coding: 0000078
    Shop #: WSC 02974 995 88202
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 042 S HW: 02E 927 770 AE
    Component: GSG DSG 070 1102
    Revision: 04507000 Serial number: 00000511141080
    Coding: 0000020
    Shop #: WSC 06314 000 00000
    VCID: 234EEDD2DD8FEE04
    1 Fault Found
    18275 - Powertrain Data Bus: Missing Message from Steering Wheel (J527)
    P1867 - 000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Reset counter: 40
    Mileage: 119442 km
    Time Indication: 0
    Date: 2013.01.19
    Time: 18:38:52
    est il possible que la boite de vitesse mette la voiture en defauts car il y a un autre code qui correspond a la boite signalent probleme de pression de boite de vitesse merci pour vos suggestions. j 'ai supprime l'egr et desactiver et changer le papillon de volet des gaz...
    Voiture concernée : Volkswagen bora variant - ajm - swapp asz
  3. Re : J'ai un probleme sur audi a3 tdi 105 8P
    Problème resolu .boite dsg en mode sécurité manque pression hydraulique dans la boîte .
  4. michophe
    Sujet Résolut a ta demande
    Merci encore
  5. Re : J'ai un probleme sur audi a3 tdi 105 8P
    Résolue comment ?
  6. Re : J'ai un probleme sur audi a3 tdi 105 8P
    Apres passage chez audi le souci perdure j ai les nerfs,,,,,,,
    turbo neuf
    debimetre neuf
    embrayage et boite neuf
    je vais changé la n 75 pour voir;;;;;;
