Probleme volant multifonction
Discussion dans 'Equipements électriques' créé par deyous, 31 Août 2010.
  1. deyous
    deyous Nouveau
    bonjour Yousef de Bruxelles
    je viens demande de l aide ici aussi (forum audipassion)
    en chipotant dans le menu caché du MMi (audi a6)
    je l ai bootloader, du coup reinstallation mmi etc...
    maintenant les touches du volant ne vont plus, qqun peut il m eclairer au niveau du diagnostic merci..
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F2 910 402 HW: 4F0 907 401 B
    Component: 2.7L V6TDI G000AG 0040
    Revision: --H01--- Serial number:
    Coding: 0011372
    Shop #: WSC 02334 785 00200
    2 Faults Found:
    000387 - Fuel Temp. Sensor A (G81): Open or Short to Plus
    P0183 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 5
    Mileage: 142332 km
    Time Indication: 0
    Date: 2010.08.30
    Time: 17:47:16
    Freeze Frame:
    RPM: 756 /min
    Torque: 78.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.15 V
    Pressure: 475.7 bar
    Temperature: 77.4°C
    005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
    P161C - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 142332 km
    Time Indication: 0
    Date: 2010.08.31
    Time: 10:35:01
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.48 V
    Duty Cycle: 15.8 %
    Temperature: 19.8°C
    Readiness: 0 0 0 0 0
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F1 910 732 D HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 350FU057574673
    Coding: 0030306
    Shop #: WSC 00000 000 08192
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H07 0050
    4 Faults Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 142332 km
    Time Indication: 0
    Date: 2010.08.30
    Time: 17:45:24
    01325 - Control Module for Tire Pressure Monitoring (J502)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 142332 km
    Time Indication: 0
    Date: 2010.08.30
    Time: 18:48:32
    01964 - Control Module for Seat & Steering Column Memory (J136)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 142332 km
    Time Indication: 0
    Date: 2010.08.30
    Time: 18:48:59
    01319 - Control Module for Distance Control (J428)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 4
    Mileage: 142332 km
    Time Indication: 0
    Date: 2010.08.30
    Time: 18:49:15
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 887 L HW: 4E0 919 887 C
    Component: MNS ECE H44 0690
    Revision: 00000000 Serial number: 305FM057607731
    Shop #: WSC 02331 785 00200
    1 Fault Found:
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 142332 km
    Time Indication: 0
    Date: 2010.08.30
    Time: 17:46:36
    Freeze Frame:
    Bin. Bits: 0100
    merci bcp
  3. deyous
    deyous Nouveau
    Re : Probleme volant multifonction
    personne? :cry:
  4. deyous
    deyous Nouveau
    :evil: y a vraiment personne pour m eclairer? :?
  5. electroman
    Tournai, Belgium
    Bora
    280000
    asz
    Bonsoir a tous
    efface tes defaults et roule 1 jour ou 2
    et ensuite repasse le vag dessus
    sinon tu as un default avec ta sonde temperature carburant
    ensuite ta bougie de prechauffage hs cylindre 3
    07 affichge commande l'adaptation est pas correct ,car default avec pressions des pneus , default avec parking control
    Freddy
  6. deyous
    deyous Nouveau
    merci pour les infos,
    la pression des pneux? quel est le rapport avec le volant multifonction?
  7. electroman
    Tournai, Belgium
    Bora
    280000
    asz
    Bonjour a tous
    j502 c'estton module pour voir la pression des pneus
    et c'est ton appareil qui le détecte ou c'est mal coder
    Coding: 0030306
    Freddy
  8. deyous
    deyous Nouveau
    merci pour les infos mais la je tourne en rond, pour la pression des pneux je ne pense pas que j ai cette option, j ai regarde le code pour le volant multi et il a l air bon mais ni commande vocale ni tes touches ne vont..
    y aurait un moyen de recuperer ce volant multi ? desole je ne suis qu un debutant..
  9. deyous
    deyous Nouveau
    ok option volant multi recupere le reste a voir....
  10. Venuz-Planeta
    Venuz-Planeta Enthousiaste
    Dax, France
    Bonjour, j'ai le même soucis pour les commandes aux volants.
    Comment faire ?
  11. romarin27
    romarin27 Nouveau
    Idem pour moi que une Q5 ! J'ai fait 2 ou 3 motif sur et depuis perte du volant multi...
    Comment on fait pour le réactiver ?
    Les motif effectué était :
    -Suppression du témoin de ceinture et bip de ceinture
    -tentative d'ajout du controle de pression des pneus sans résultat
    -Activation du menu caché sur me MMI
    -Activation du check des aiguilles au démarrage
    -Logo RS au démarrage du MMI
    Je pense que c'est la pression des pneus qui a foutu la *****...
    Merci pour votre aide car c'est vraiment ennuyeux et je suis vraiment débutant sur le VAG COM :--:
  13. electroman
    Tournai, Belgium
    Bora
    280000
    asz
    si tu as pas ce fameux J502 pour la pression des pneus
    c'est qu'il est cocher dans ton gateway
    dans le n° 19 gateway regarde pour enlever le V pour qu'il ne le prend plus en compte
    mais avant de modifier un code ;prendre note du codage
    comme ca tu sait revenir en arriere
    Freddy
  14. romarin27
    romarin27 Nouveau
    Je viens de faire un scan complet j'ai essayé d'effectuer 2 ou 3 motif mais sans effet. Je ne trouve aucun moyen de réactiver les commandes du volant alors qu'il est pourtant actif dans la rubrique concerné.
    En revanche j'ai visiblement d'autres erreurs...
    Je me suis bien amusé a activer les 2 ou 3 conneries sur le Q5 mais je commence a m'en manger les doigts ! Ca manque vachement les commandes au volant !
    Merci pour votre aide car j'ai pas bien envi de l'envoyer chez Audi pour faire la réparation de mes bêtises ... :--:
    PS : pour Freddy
    Je n'ai pas tout compris mais il semble que je n'ai pas ce J502.
    L'option contrôle de pression des pneus n'étais pas en standard sur mon Q5 mais je pensais réussir a l'activer avec le VCDS puisque c'est le module ABS qui le gère, je n'y suis pas parvenu mais je pensais avoir tout remis comme avant... J'ai également activé le menu caché sur le MMI j'ai peut être fait une connerie directement dessus?
    En faisant le scan j'etais persuadé d'avoir une erreur au niveau du volant mais cela ne semble pas être le cas, j'ai l'impression que ces erreurs n'ont rien a voir :-Fureur-:
    Quelqu'un peux t'il me dire a quoi corresponde ces erreurs et me rendre mon bien aimé volant multifonctions :p
    Merci pour vos conseils et votre aide, après je range cette saloperie de câble et je le touche plus jamais !!!
    Sunday,08,January,2012,19:38:45:10074
    VCDS Version: Beta 11.3.0
    Data version: 20110801
    Chassis Type: 8T0
    Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6D 72
    VIN: WAUZZZ8R09A031791 Mileage: 42100km/26159miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 022 NH HW: 03L 906 022 B
    Component: R4 2,0L EDC H01 4388
    Revision: 11H01---
    Coding: 01210023180F2118
    Shop #: WSC 06335 000 00000
    ASAM Dataset: EV_ECM20TDI03L906022NH A01004
    ROD: EV_ECM20TDI03L906022NH.rod
    VCID: 78FBECD377F7
    No fault code found.
    Address 03: ABS Brakes (J104) Labels: 8R0-907-379.clb
    Part No SW: 8R0 907 379 C HW: 8R0 907 379 C
    Component: ESP8 quattro H06 0230
    Revision: -------- Serial number: --------------
    Coding: 0C5500
    VCID: 408B44336FA7
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 AQ HW: 8K0 907 064 AQ
    Component: BCM2 1.1 H80 0145
    Revision: 00002001
    Coding: 030500
    VCID: 7F0907CF52D9
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H37 0060
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: ELVAUDIB8 H36 0041
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AB HW: 8T1 820 043 AB
    Component: KLIMA 3 ZONEN H06 0150
    Revision: C0000000 Serial number: 01070220090395
    Coding: 34110000
    VCID: 71EDD1F7148D
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
    Component: BCM1 1.0 H22 0253
    Revision: 04022001 Serial number: 00000000209917
    Coding: 260050914034AF010001000000001D0D0F1C070800010141000000
    VCID: 2F69178FC239
    Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119
    Component: WWS416 090129 H10 0041
    Coding: 01DD13
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559
    Component: RLS H04 0003
    Coding: 024D25
    Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
    Component: E1 - LDS H07 0080
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 G HW: 8K0 919 475 A
    Component: PARKHILFE 8K H06 0040
    Revision: 11001001 Serial number: 40040904302726
    Coding: 100005
    VCID: 3D753DC71855
    Address 15: Airbags (J234) Labels: 8R0-959-655.clb
    Part No SW: 8R0 959 655 B HW: 8R0 959 655 B
    Component: AirbagVW-AU10 H03 0310
    Serial number: 003E8D0352W.
    Coding: 30343131313030303030554A304C38523053
    ASAM Dataset: EV_AirbaAU10SMEAU416 001001
    ROD: EV_AirbaAU10SMEAU416.rod
    VCID: 43814B3F7EB1
    Driver's Airbag Crash Sensor:
    Serial number: 6334MSME4425146CB
    Passenger Side Airbag Crash Sensor:
    Serial number: 6344MSME445526303
    Driver's Rear Airbag Crash Sensor:
    Serial number: 6352QSME222306080
    Passenger's Rear Airbag Crash Sensor:
    Serial number: 6362QSME3B21242CF
    Driver's Front Airbag Crash Sensor:
    Serial number: 63732SME491D1E323
    Passenger's Front Airbag Crash Sensor:
    Serial number: 63832SME3C1C37285
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H15 0013
    Revision: -------- Serial number: 90319IB5000DW
    Coding: 000017
    VCID: 3D753DC71855
    Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
    Part No SW: 8R0 920 930 C HW: 8R0 920 930 C
    Component: KOMBIINSTR. H08 0224
    Revision: 00200000 Serial number: 9ER737829
    Coding: 030D220002000008030000
    VCID: 346318E32B1F
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 P HW: 8T0 907 468 K
    Component: GW-BEM 4CAN-M H09 0095
    Revision: EB500046 Serial number: 4600E091288042
    Coding: 000303
    VCID: 4E976A0BA5F3
    Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
    Component: J367-BDM H07 0107
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
    Component: TSG FA H11 0250
    Revision: Serial number: 0000008488224
    Coding: 011D02205000440004
    VCID: 418D413764AD
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0116832854
    Coding: 01000620203934C0052005
    VCID: 7F0907CF52D9
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
    Component: TSG BF H11 0250
    Revision: Serial number: 0000008476993
    VCID: 408B44336FA7
    Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
    Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
    Component: EPB Audi B8 H08 0080
    Revision: 00000003 Serial number: 00000000307743
    Shop #: WSC 00000 000 00000
    VCID: 33611BFF2E11
    Address 55: Xenon Range Labels: 8K0-907-357.clb
    Part No: 8K0 907 357 B
    Component: Dynamische LWR H01 0030
    Revision: 00000001 Serial number:
    Coding: 0000006
    Shop #: WSC 06334 000 00000
    VCID: 346318E32B1F
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4F0 035 056 B HW: 4F0 035 056
    Component: Radio U STD H45 0020
    Revision: AB001007 Serial number: 342BU097563437
    Coding: 010003020100000001
    VCID: 1F49E74FB299
    Address 5F: Information Electr. (J794) Labels: Redir Fail!
    Part No SW: 8T1 035 666 D HW: 8T1 035 666
    Component: H-BN-EU H64 0047
    Revision: -------- Serial number: 321BQ097554805
    Coding: 01010006030581FD01000E1E000000030001
    Shop #: WSC 07380 995 60667
    VCID: 3B7133DF0641
    Subsystem 1 - Part No: 8R0 060 884 C
    Component: EUROPE 2008 5608
    Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
    Component: DU7 High H43 0306
    Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
    Component: E0380 Bedient H08 0100
    3 Faults Found:
    00658 - Control Head
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 41424 km
    Time Indication: 0
    Date: 2011.12.27
    Time: 17:56:31
    Freeze Frame:
    Voltage: 12.40 V
    Bin. Bits: 010
    02244 - Button in Control Head is Stuck
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 185
    Mileage: 41660 km
    Time Indication: 0
    Date: 2011.12.31
    Time: 17:29:49
    Freeze Frame:
    Voltage: 14.70 V
    Bin. Bits: 10000000 00000000
    Bin. Bits: 00000000 00000000
    01043 - Control Module; Incorrect Software Version
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 22
    Mileage: 36836 km
    Time Indication: 0
    Date: 2011.09.20
    Time: 10:36:25
    Freeze Frame:
    Bin. Bits: 00000000 00010000
    Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
    Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
    Component: TSG HL H10 0251
    Revision: Serial number: 0000008469483
    Coding: 010C02204000240004
    VCID: 43814B3F7EB1
    Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
    Part No SW: 8R0 827 851 A HW: 8R0 827 851
    Component: J605 Master H27 0290
    Revision: -------- Serial number: 8R0827851
    VCID: 3A7F36DB097B
    Subsystem 1 - Part No SW: 8R0 827 852 A HW: 8R0 827 852
    Component: J756 Slave H27 0290
    Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
    Component: TSG HR H10 0251
    Revision: Serial number: 0000008469490
    VCID: 43814B3F7EB1
    End ---------------------------------------------------------------------
  15. electroman
    Tournai, Belgium
    Bora
    280000
    asz
    c'etait pout deyous le j502
    freddy
  16. jujuA4
    jujuA4 Débutant
    Slt,
    je suis également preneur d'info pour l'activation des commandes MF, je ne suis pas tout a fait dans le même contexte car je viens de les installer sur une A6 2006.
    Mais je pense que mon problème est similaire car les MF s'allument mais ne répondent pas. En revanche les palettes de vitesses fonctionnent.
  17. romarin27
    romarin27 Nouveau
    Essaye si cela n'est pas déjà fait d'aller voir dans le VCD S menu 16 steering whell puis code long et vérifie que le volant multifonctions est est bien actif. Chez moi il est coché mais ne fonctionne pas :-Fureur-:
    Il semble que ce sujet ne passionne personne...
    Merci pour votre aide,
  18. caramail12
    caramail12 Modérateur
    Rodez, France
    Bonjour donc effectivement si tu n'a pas de surveillance de pneus c'est que ton gateway est mal codé
    Il faut déja commencer par là
    Controler le codage de l'autoradio
    controler le codage des commandes au volant
    faire une lecture des blocs de valeurs de mesure pour voir si le calculateur detecte bien les commandes aux volants .
    Aprés quand on connait pas trop il faut mieux un vas 5054 a qu'un vcds c'est plus clair surtout pour avoir les codages
  19. jujuA4
    jujuA4 Débutant
    Je ne pense pas avoir le long codage sur mon A6 car elle est de 2006. IL me semble qu'il est apparu avec le "facelift" sur les A6.
    Je vérifierai tout de même.
  20. jujuA4
    jujuA4 Débutant
    Slt j'ais enfin réussi a faire fonctionner mes commandes MF.
    Pour le codage :
    En plus de modifier le codage du module 16, il faut en modifier un dans le module 7.
    Module 16 > mettre le 4ème chiffre à 2
    Module 07 > choisir le "chanel" 001, entrer cette valeur 04096 = Multi-Function Steering Wheel installed (PR-1XW) puis redémarrer le MMI pour activer la modif.
    Pour le redémarrage du MMI, il le trouve dans le menu déroulant de l'interface, donc le sélectionner mettre le bit a 1 et ça redémarre.
    Par contre avec cette procédure il est indispensable d'avoir le câble et le logiciel.
    (peut être qu'il est possible de le faire avec le menu caché, mais pour cela il faut déjà y avoir accès)
    Je ferai un sujet tuto sur le forum, en regroupant toutes les infos qui m'on été utiles,
    je pense que ça pourra en aider d'autre.
    Slt.
  21. romarin27
    romarin27 Nouveau
    Cool pour toi, en ce qui me concerne toujours pas de solution puisque le module 07 n'est pas activité sur le Q5...
    Si tu as une idée ...?
  22. jujuA4
    jujuA4 Débutant
    Je sais comment activer une fonction dans un module, mais je ne sais pas activer un module...Dsl.
    Si je trouve l'info, promis jte la donne. ;)
