suite a check Vag ...Golf 4 1.8T
Discussion dans 'Equipements électriques' créé par sidney_78, 26 Octobre 2009.
  1. sidney_78
    sidney_78 Nouveau
    Bonjour ,
    Suite au passage du vag de ma voiture voila ce qu'il en ressort pouvez m'en dire un peu plus ?
    Merci d'avance :
    Chassis Type: 1J - VW G/J/B Mk4
    Scan: 01,02,03,08,15,17,19,22,35,46,56
    Address 01 -------------------------------------------------------
    Controller: 06A 906 018 BB
    Component: 1.8L R4/5VT MOTR HS D04
    Coding: 04000
    Shop #: WSC 00000
    3 Faults Found:
    16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    P0116 - 35-10 - - - Intermittent
    00671 - Cruise Control Switch (E45)
    27-10 - Implausible Signal - Intermittent
    00282 - Throttle Position Actuator (V60)
    Readiness: N/A
    Address 03 -------------------------------------------------------
    Controller: 1J0 907 379 E
    Component: ABS/EDS 20 IE CAN 0001
    Coding: 13504
    Shop #: WSC 01317
    1 Fault Found:
    01312 - Powertrain Data Bus
    37-10 - Faulty - Intermittent
    Address 08 -------------------------------------------------------
    Controller: 3B1 907 044 A
    Component: CLIMATRONIC S 7.0
    Coding: 01000
    Shop #: WSC 01317
    2 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
    30-00 - Open or Short to B+
    01274 - Air Flow Flap Positioning Motor (V71)
    35-00 - -
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 1J0 919 880 B
    Component: A4-KOMBIINSTR. VDO V10
    Coding: 04142
    Shop #: WSC 00000
    IMMO-IDENTNR: VWZ7Z0V0242218
    No fault code found.
    Address 46 -------------------------------------------------------
    Controller: 1J0 959 799 J
    Component: Zentral-SG Komf.0001
    Coding: 00257
    Shop #: WSC 01279
    4 Faults Found:
    00928 - Locking Module for Central Locking: Front Driver Side (F220)
    00943 - Heated Exterior Mirror: Driver Side (Z4)
    35-00 - -
    01332 - Door Control Module: Passenger Side (J387)
    53-00 - Supply Voltage Too Low
    00944 - Heated Exterior Mirror: Passenger Side (Z5)
    35-00 - -
    End -------------------------------------------------------
