Tutoriel VCDS Release 25.3 - may prompt you to do firmware update before you can scan (1 Membre)
BushPigg
Donateur 🤝
South Africa
Caravelle
AXE
KCQ
WV2ZZZ7HZ6H043488
Hello everyone
I yesterday updated my VCDS software to version 25.3, and when I tried to run a scan, I was not able to.
I have a Hex-V2 connector (original Ross-Tech...).
As soon as I opened the software, it prompted me to update / check my firmware, and all options were greyed out / not able to click.
In order to be able to use the scan function, perform the following steps: -
1. Connect cable to OBD port and computer
2. Open VCDS (always "open as admin...")
3. Click on "Options" (bottom right)
4. Click on "Config"
5. Select "Update" tab
6. Click on "Check for updates"
- Update if required
- Then close this window
7. Click on "Test" in the original "Options" window
8. If Test ok, CLICK ON SAVE!!!
9. Return to main window, and you will be able to scan etc :-)
It is very important that you click on SAVE 🤓
I hope this helps someone
A new issue of the 25-3 now labelled 25-3-0 has been issued this morning , correcting the trouble of the previous revision 25-3 .
En Français : une nouvelle mise â jour a èté publiée ce matin nommèe 25-3-0 qui corrige les dèfauts de la révision 25-3 publiée récemment .
