PETKA 8.8 (1 Membre)
hello possible d'avoir le code de déblocage svp ,merci pour tout : ID: aDBUvHl0CUqLKKf0Rk6nFSYQDRUujmzW-6479_A72F_C249_0143.
@vlasoff
weWiYYaWHTmbpkZgTb9On9RRsb4CzgR0WK7KZNxGSkT9MrIJvx0JGxuS4mkcO22uTPnJswZA+07
HJXLFjAm0fWQ+MdLhwZm81KoCD1AMgkdfToNSEdQM/JyTlHnZX6TxBBcotU0rwA0xnU8Ezghd2T
UIMYkGuTqprHzowbzyAqm1X9XvdW7BuU/uxKBJX4i1T14uighRtVv7uq+ekwpVMfOEeKS+lVZ5s
gPC+H445lgkwzdMzEyU7VaSlmujXE8ZP5NK+gVF/RUMXUJLXF3dLzyeYaK+aSvhjV0cQXkUZbyJ
4FUKNGgrCKfe0x6RPTk2dmS1+nvzQNNUdwJUIsqkhQ==
@BushPigg
iObdoMCy8AyPMHRzIJWAQaeF/6HIbEQb/WLoYDu8KkJY+wix9xH30BB8Gju90Rjf5sNKIP1STkx
hKReyeQlK9xBGX0qnlBPvvVNITQ9X212A311r1ErHXr/+ar7nhZuGIS7pqsxpSokv0jcVZaS3kk
x7jeLbRUbEUa7lwe8a13ZEUhNbvZFNcJ2aAE+5ZC7K4YVh7nLxgXRV9KqqHh4gXWt6i/T/yg8Tt
zUelAvMtZBgjuaCQ9uBsOiiX7Mw8As/ejA74opS1a1FfsttdmLNGERci8xb9FkT4i5F3fdo/wZm
TFjzpclpS1OCn24bvgbb5jD8i09CpsYFBsRrTx5UhQ==
@bidikman
dT3Eu9k+aJIMzDfGpi8sGw+JpyEyWymM2t03+rh5K7sTRNucetdUbxZNUzLKjJ6yk7ZerPSCoKb
FMqGYeHfzws26HB9lT7RQ3B9y8sGsioGb1HBmNNqsuPEdUYysR211ihV3JuytTafQiwfKQ6mEdp
yLn4ePbDtj8wPcKHISmU2/ZR+SGvY1TcRdAiQgKhT0C2+jnFsLK16oNjjBoUvfA2oTltha1si4E
mEgxS/ythjLLXpcC4DwgcDuhLYKFFFS5wA9iNXmg/p7Xx5zTrFF/mgqy+ax4aYhY6WUKwW6GmnD
rg1nfF0RdJyZxrW2Sq3X4M3x8iHwDi0n2Fm3haMqbQ==
Bonsoir a tous.
Je voudrais savoir ci c'est possible d'installer petka 8.8 sur Windows 11 pro ?
Ci possible pouvez vous me dire comment faire ?
cordialement
franc77
5F05lP2nO7lTT8A+krb8W2bsdpG+9z/Mpkk0ExL2Xg4qo624nh3OSG42wCPiX4mG-ACE4_2E00_2B06_D175_2EE4_AC00_0000_0001.
Bonsoir a tous.
cordialement
franc77
Salut, as-tu essayé ? Parce que je ne vois pas où serait la difficulté d'installer PETKA sur un Win 11 Pro !? :unsure:
@gregmurf
wo78UMUwxoujVdN0HzVwCWnxeYpqUpSxosFFyujlmMFoNW3Pr2r5IM3MUvdGM2xg+ZNC0dvV8EI
YKXjBMCkJxM5FKS6IZHyiMIbXLlBTXSCrmf+SrVIpGSHjlINUo7AOSIB7nsrnpsgA78afSnJDZg
2Hn9+jJsRffkf39bttN9bphFvUazWpsn/fg9dRibNlei0XSh9h0XAIENGCYPT1haMgU6BuE7mMV
FCjp+GecdFts8jTIShTDOWFSYtDJh0mtPUhkVFJU/Ou3f9en2USyi3KWysQhMPcWsD66BfFvJRn
8KXP2ouxLBiNm33nJxW+MLH0Dam99cvxqjV83Mr3DA==
Oui, on peut l'installer sur W11 Pro (je l'ai fait sur un fixe).
Rien de particulier à faire par rapport à W8 ou 10. Même procédure.
Mon PETKA fonctionnait parfaitement, et du jour au lendemain 'j'ai le message, "Hardlock pas trouvé" ;
Avez-vous déjà rencontré ce problème ?
J'ai rien changé sur mon PC.
Hi Quattro10
You can select the language when installing for anything up to PETKA 5.3 and 2016 database....
For anything after 2016 database, or PETKA 6 (after PETKA 5.3...) it will be in German....
I am testing whether I can install PETKA 6 and only the 2016 database to see if it is still available in English (and NOT German only...)
Hi,
Yes, is OK, thanks
Merci d'avance pour la clé de cet iD :
5BDK2RF6xicruihCZga7mg==-2017E29CEC92
(seconde installation sur portable sous W10 Pro)
Petite question : y a t'il un intérêt à upgrader de la version 8.5 à la 8.8 ?
@tom11
tkKcEvxjriAfTUVzHH2njBLdUCKi5AEr8LvNmwHXoMDvB7hmAZUpLNiZ+S2Ayc43iCl01IcEz54
ona5dl6mmzFZShHyBjEmNlLaNxXP2ierso2cRk8W/r+Q6bHYLU9TpFxO81ugEjSeeIEwjrNJSUt
ZcM3l5g6B85XIVXUeNmmKp33C1oud4CxIRXyFhyAjq+X1flWy2oICOrdxtUjHWY2ejHvz3SZcgp
pWlxMXg3Q76NcL6AkvWE2JzbnZPF6lAhJwEXjpWaokkxGxd+0L8lCw4qtR2+JsLhJprRAyrsl5W
vDQ20K4Ci2V2P14Dqzde5OQWOCXUDrTZRlA6kf+NfA==
@Xtremlimit
IZYkfQ7JBn09WgRbX6EP7odLyWOLzubHKekJHj1Mvc2ixpZM0QM/O0VFNm4FbbFJ6j/540y3jU7
PpZhZTqz8mu1Ivsgp6R9421kQ+Ogo75w8fKEhyUUOtedIJSV5GOyvH6BehVoV1zsgMttX4uJtG4
aLPEEoWYuyOGn0O5LIk60n9Qlu6jR4AKAaj+K9gbnTxnF+d5QyMHigLUkwXucJQtIax6qkNEzxJ
52VhMs9y1GWyr4RVdNuf7RWMZLEQh6O5veE35P9mVj8LD3wtgjHsrylnxYFcmpEidaM30Q14wNI
vWFnvh2O9hw+9lKBE8xlsZAdWAdXR5KKG4qdPrcYcA==
@Quattro10
vous avez besoin d'un numéro de série.
les maj de prix fonctionnent chez vous ?
Les données c'est ok chaque semaine mais plus les prix
Merci Vagcom pour l'Id mais ayant fait tomber le portable... l'écran est HS (mais quel c** !).
Transfert du disque dur sur un autre portable (provisoire, car celui-ci à un clavier récalcitrant et ne charge plus... à force de récupérer de vieux bousins...), mais l'iD change un peu (je suppose que le hardware joue sur l'Id : passé d'un Asus Intel Pentium à un Packard Bell Intel I3).
Nouvel Id sur le Packard :
iBZkchF6xicruihCJqLqja7PlJLOGLkMQj2rUQ==-2017E29CEC92
Merci d'avance
Bonsoir a toute l équipe pouvez vous s il vous plait me donner la clef merci
HARDWARE ID KHcX9P3z/tnvwKg/drota+6jOdoGnVBbutYEGw==-S3Z2NB0NA34947B
