Wednesday,14,July,2021,17:36:07:05101
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
VIN: WV2ZZZ7HZ5H097010 License Plate:
Mileage: 189740km-117898mi Repair Order:
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ5H097010 Mileage: 189740km-117898miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 BF HW: 028 101 183 7
Component: R5 2,5L EDC G000SG 7000
Revision: 12345678 Serial number: VWZ7Z0E1788298
Coding: 0001172
Shop #: WSC 02756 785 00200
VCID: 55F78BD0C91068738C5-513C
1 Fault Found:
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
Freeze Frame:
RPM: 2268 /min
Torque: 370.9 Nm
Speed: 101.0 km/h
Load: 63.5 %
Voltage: 14.21 V
Bin. Bits: 00101000
Absolute Pres.: 2284.8 mbar
Absolute Pres.: 1836.0 mbar
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 7H0-907-37x-ESP-A.lbl
Part No: 7H0 907 379 M
Component: ESP ALLRAD MK25 0203
Coding: 0006687
VCID: 3FDB49785B6C8223B69-5118
No fault code found.
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 7H5 907 040 B
Component: CLIMAtronic T5 X 3717
Coding: 0000040
Shop #: WSC 61431 001 1048576
VCID: 2A0D082CB0EE178BF17-5118
Subsystem 1 - Part No: 7H7 907 049 A
Component: Display_2_ClimaT5 X 0307
1 Fault Found:
01186 - Rear Air Distribution Flap Motor (V136)
000 - - - Intermittent
Address 09: Cent. Elect. Labels:. 7H0-937-049.lbl
Part No: 7H0 937 049 P
Component: BORDNETZ SGVER 1.0 1901
Coding: 0000102
Shop #: WSC 00012 000 00000
6 Faults Found:
01598 - Drive Battery Voltage
002 - Lower Limit Exceeded
00991 - Interior Lights
012 - Electrical Fault in Circuit - Intermittent
01336 - Company Data Bus for Comfort System
004 - No Signal/Communication - Intermittent
01330 - Central Control Module for Central Convenience (J393)
01331 - Door Control Module; Driver Side (J386)
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 11 AIRBAG VW61 0R 0003
Coding: 12593
Shop #: WSC 02756
VCID: 270BF118A6FC2AE3EE9-5118
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00119
Shop #: WSC 02770
VCID: 2F3B19388E0C72A3269-5160
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H5 920 870 J
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05112
Shop #: WSC 61427
VCID: 382922647B42B51B773-5118
WV2ZZZ7HZ5H097010 VWZ7Z0E1788298
2 Faults Found:
49-10 - No Communications - Intermittent
01322 - Control Module for Multi-Function Unit (MFA) (J501)
Address 18: Aux. Heat Labels: 7H0-819-008.clb
Part No: 7H0 815 071 C
Component: Standheizung 0207
Shop #: WSC 00000 000 00000
VCID: 2809F224AEE2259BE73-5118
1 Fault Found:
00664 - Fuel gauge
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00022
Shop #: WSC 02756
VCID: 70B9DA4453B22D5B7F3-5118
3 Faults Found:
01320 - Control Module for Climatronic (J255)
Address 22: AWD Labels: 7H0-907-554.clb
Part No: 7H0 907 554 A
Component: HALDEX 4Motion 0105
Coding: 0000001
Shop #: WSC 02771 785 00200
VCID: 2E05043C8C067BAB2DF-5118
Address 37: Navigation Labels: 7L6-919-887-CD.lbl
Part No: 7H0 919 887 D
Component: Navigation 0634
Coding: 0000002
Shop #: WSC 02770 785 00200
VCID: 3D27337051609033A45-5118
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C Komfortgerát 0004
Coding: 00073
Shop #: WSC 02756
VCID: 323D104C9D3E5F4B497-4AE0
Subsystem 1 - Part No: 7H1959801A
Component: Tõrsteuer.FS KLO 0203
Subsystem 2 - Part No: 7H1959802A
Component: Tõrsteuer.BF KLO 0203
Address 56: Radio Labels: 7L6-035-186-CD.lbl
Part No: 7L6 035 186 A
Component: Radio 0634
Coding: 0006405
VCID: 313F1F409D38645330D-5118
Address 76: Park Assist Labels: 7E0-919-283.lbl
Part No: 7E0 919 283
Component: Parkingsyst. T5 T5M 801
Coding: 00127
Shop #: WSC 02756
VCID: 6C81CE347F9AC9BB43B-513C
Address 77: Telephone Labels: None
Part No: 7H0 035 729 F
Component: CIB PAH HW 203 SW 0309
Coding: 0000364
VCID: 2F3B19388B0C72A3269-5118
Address 7D: Aux. Heat Labels: None
Part No: 7H0 819 002 K
Component: Luftstandheizung, D 0426
Revision: 00052426 Serial number: 0097616
VCID: 2E05043C8C067BAB2DF-4B1E
End----------(Elapsed Time: 05:02, VBatt start/end: 12.3V/12.3V)----------
