Friday,16,August,2019,16:47:47:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
VIN: WAUZZZ8UXGR008974 License Plate:
Mileage: 49920km-31018mi Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 5F 62 72
VIN: WAUZZZ8UXGR008974 Mileage: 49920km-31018miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CUVC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 BF HW: 04L 907 309 K
Component: R4 2.0l TDI H20 2911
Revision: 8AH20---
Coding: 02190012042601082000
Shop #: WSC 36563 002 1048576
ASAM Dataset: EV_ECM20TDI01104L906016BF 004002
ROD: EV_ECM20TDI01104L906016BF_004.rod
VCID: 6ED378B9B197023A37-803A
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 5N0-614-109-V1.clb
Part No SW: 5N0 614 109 CA HW: 5N0 614 109 CA
Component: ESC-EBC460iV1 H08 0004
Serial number: A00U0JV
Coding: 22F124A14920E3742080440724C792C704355700508B4884
Shop #: WSC 00049 770 00152
ASAM Dataset: EV_Brake1ESCEPBTRW 003039
ROD: EV_Brake1ESCEPBTRW_003.rod
VCID: 6CD772B1878BF02A19-8038
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8U0 820 043 F HW: 8U0 820 043 F
Component: E87 Klimavoll 0210
Revision: 00H05000 Serial number: 8U0820043F
Shop #: WSC 00000 000 00000
VCID: 3467AAD1573B68EA01-8060
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 AB HW: 8X0 907 063 AB
Component: BCM PQ35 M 113 0817
Revision: AC113817
Coding: 06000A2CA805F3C0201849C02144094C53FF25AA016F912BE408878400C5
Shop #: WSC 00049 770 00010
VCID: 7CF742F1FFEB60AA89-8028
Subsystem 1 - Part No SW: 8U1 955 119 HW: 8U1 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 150427 H37 0090
Serial number: 150510134419
Coding: 0047F7
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 20293524
Coding: 02006E
Subsystem 3 - Part No: 8X0 951 177 A
Component: Sensor, DWA 0 005 0002
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 AE HW: 8X0 919 475
Component: PARKHILFE 4K H03 0080
Revision: 11001001 Serial number: 37061513000343
Coding: 080008
Shop #: WSC 00049 770 00119
ASAM Dataset: EV_EPHVA14AU21X0000 003007
ROD: EV_EPHVA14AU21X0000_003.rod
VCID: 09192B25A839450282-805C
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8U0 959 655 C HW: 8U0 959 655 C
Component: AirbagVW-AU10 H09 0900
Serial number: 003PAR0BC5MT
Coding: 304D3232333030303030554A304C38553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001010
ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 479DED1DFEADF37254-8012
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.V H02 ----
Serial number: 3496KSME0F191437ZZZ-
Crash sensor for side airbag: front passenger side:
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.V H02 ----
Serial number: 3506KSME522A1437ZZZM
Crash sensor for side airbag: rear: driver side:
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME2E203437ZZZO
Crash sensor for side airbag: rear: passenger side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME61031437ZZZF
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Component: F.Sens.Fahr H02 ----
Serial number: 3555USME61763C36ZZZ3
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 D HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: FF010018 Serial number: 20150521201231
Coding: 1184204000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 3B7581EDB265A792C0-806E
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 8U0 951 528 E HW: 8U0 951 528 E
Component: E221 - MFL H09 0010
Serial number: 16 04 2015 30049371
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8U0 920 930 G HW: 8U0 920 930 G
Component: KOMBI_MEDIUM H04 0470
Serial number: 00000000000000
Coding: 12CF01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
ROD: EV_Kombi_UDS_VDD_AU10.rod
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 AQ HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0090
Revision: 1P140041 Serial number: 4141P1551001D0
Coding: FBCF1A5A000108610253
Shop #: WSC 45148 001 1048576
VCID: 11290345C8697DC24A-8044
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 42135F20231491080058
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 15134000939011200181
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7531
Serial number: HA1-00009.04.15
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 52ABCC4905EF46DA33-8006
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Component: IMMO H04 0470
Serial number:
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H11 0415
Revision: -------- Serial number: --------------
Coding: 011E02201C00000000
VCID: 52ABCC490DEF46DA33-8006
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
Component: J500__APA-BS KL.377 1401
Revision: 1BH04841 Serial number: 00151200036501
Coding: 0000258
VCID: 4189F3051889CD429A-8014
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H11 0415
Coding: 011E02201E00000000
VCID: 51A9C34508E93DC20A-8004
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 E HW: 8X0 907 357 B
Component: ****LWR12**** H02 0020
Serial number: 150515-0002-147
Coding: 11C7A41010022500
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 4487FA11CF9BD86AB1-8010
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8U1 035 193 A HW: 8U1 035 193 A
Component: RMC Cnct Nav H61 0139
Coding: 0100060002C153070823020103010000000000
VCID: 3467AAD1973B68EA01-8060
Subsystem 1 - Part No: 8X0 919 884 H
Component: P28-50-14.06 0001
Subsystem 2 - Part No SW: 8U0 919 603 A HW: 8U0 919 603 A
Component: DUBasic AU316 H42 0018
Serial number: AUZ8ZDFM503435G
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
Component: TSG HL H08 0415
Coding: 010E02200000000000
VCID: 4FADC53D1EDD2B321C-801A
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H08 0415
End-------------------------(Elapsed Time: 03:01)--------------------------
